What is the mileage cut off for Nitrous???
Old 07-11-2009, 11:08 PM
99Ls1fever's Avatar
Default What is the mileage cut off for Nitrous???
I just recently purchased a 2000 WS6 w/ 130,000 miles on it. I was woundering if I could run a 75 shot on it and how long I could run it before the engine gives?
What are you opnions on Nitrous and Mileage???
Old 07-12-2009, 07:06 AM
Danger731's Avatar
It depends on the maintenance over the years. A well maintained motor will be fine , an abused motor won't be fine even if you don't spray. My Z/28 has 120k on a 100 shot.
Old 07-12-2009, 10:33 AM
RS_SS69's Avatar
WTF? when did you get that?
Hope to see you around the shop, I think trent is awaiting your call....
Old 07-12-2009, 10:51 AM
pyro719's Avatar
I got 146,000 miles on mine with a 150 shot Been sprayin it for 2 years now
Old 07-12-2009, 04:29 PM
99Ls1fever's Avatar
It is my brothers car, once he starts defalting on the payments though I will probabley take it off his hands...
Yeah, I need to call Trent. But like everything else it all depends when I get the money.
Old 07-12-2009, 04:31 PM
99Ls1fever's Avatar
I have no idea how the maintance of the engine has been, I probabley need to do a compression check on each of the cylinders. That might be a good starting point.
Old 07-13-2009, 07:26 AM
Nick@HSW's Avatar
Yup, that's where I would start. One of our test cars has just about 115K on it now and we hit it with quite a bit. Just make sure there is a steady fuel supply and your tune is spot on, and you won't have any issues.
Nick
Old 07-13-2009, 09:33 AM
99Ls1fever's Avatar
Thanks Nick, Once I get a chance I will do a compression check on the motor.
Who all out there is spraying and how many miles are on your car?
Old 07-13-2009, 11:05 AM
Z-RATED94's Avatar
Nick
Nick, what do you consider quite a bit? Thanks
Old 07-13-2009, 12:31 PM
99Ls1fever's Avatar
Good question I was woundering the same thing
Old 07-13-2009, 01:39 PM
Nick@HSW's Avatar
Well its box stock auto with headers. We've doubled its N/A numbers on a few occasions.
Old 07-13-2009, 03:56 PM
99Ls1fever's Avatar
I like the way that Sounds!!!
Old 07-13-2009, 07:27 PM
Z-RATED94's Avatar
Must be an LT1!!!
Old 07-13-2009, 08:02 PM
99Ls1fever's Avatar
Those LT1's sure love the Nitrous
I sprayed a 100 Shot from 40,000 miles to 82,000 miles and then new motors came into play. After putting in new motors, I wish I would have ran a 150 shot or a progressive 175 shot with the stock short block.
Old 07-14-2009, 09:57 AM
blubyu02's Avatar
135,000 miles spraying a 150shot, and will till the wheels fall off
Old 07-14-2009, 10:01 AM
nitr0racing21's Avatar
115k and a 100 shot on my second bottle now, if you have ford friend they will tell you its bad to do if you have chevy friend then you know its ok lmao
Old 07-14-2009, 04:13 PM
99Ls1fever's Avatar
What was the mileage when you guys started spraying on them?
Old 07-15-2009, 11:59 AM
Z284U2TRY's Avatar
Sprayed a 99 Z from 25k-90k 100 shot mostly. hit it with 250 more than a few times. The now third owner has a 120k on the car and running a 150.
Old 07-15-2009, 12:02 PM
108K-115K I rarely ever need to spray though so I don't I want to buy a LT1(6 speed) when I get the money and spray the bitch LT1 and LS1 heads/motors love N2O
Old 07-19-2009, 05:24 PM
Pate_2008's Avatar
i have 150,000 miles on my car and have put 3 bottles through it so far with no problems.
