Should i change my head gasket??????
Im about to install my motor in my car. Built 347 with stage 2.5/5.3 heads and vindicator camshaft.. It also has 2cc lunati pistons. I have a pair of oem mls gaskets. Should i use those or what gaskets should i go with to get a better compression????
IMO I would use the stock gm gaskets. They are very robust. If not you can use the cometic, but keep in mind u have to measure the ptv clearence and if u dont know what u are doin u can screw everything up. The GM gaskets arn't that bad thats what I am using on my afr heads.
