What size shot are you running on your stock bottom end?
Like the title says what shot are you running on your stock bottom end and what's
Your mileage on the motor. Also how's the motor holding up.
Thanks Raul
Thanks Raul
Just hit 50k miles. Stock bottom end with ARP ProSeries rod bolts.
Last fall I hit it with a 200 shot for a bottle's worth. Handled it fine. But then again it was only one bottle.
Likely staying with a 150 from now on.
I know a guy who is running a Progressive 175 shot out here with a 75 off the line and a 100 shot at the sixty foot. He has TSP 5.3 Heads and a Custom Grind Cam 649/609 109 LSA and running 11.9 at 5,800 feet.
You will need another fuel pump or switch your out to a 255, and you might need bigger injectors. Not positive on the injectors but it probabley wouldnt be a bad idea at that point.
hit it with a 150 shot for over 150 passes. over 50 passes with a 200+ hit till a piston came apart. bottom end was pretty tired, i really beat the hell out of that engine on the street too made over 300 na passes on it as well
