power window quit
Old 07-13-2009, 06:22 PM
CaMaRo67RS355's Avatar
Question power window quit
rolled down the windows in my ss and rolled them back up to find the drivers quit working and didnt budge when i push the button i here a clicking so i guess that mean the switch is working... im getting ready to check the fuses now but if its not a fuse is it the window motor? wasnt slow rolling down or anything it just wont roll back up now.
thanks
Old 07-13-2009, 06:44 PM
Save the manuals!
wssix99's Avatar
Yep - its the motor.
Old 07-14-2009, 02:26 AM
PIZDETS's Avatar
advance has a good price on reman'd motors
Old 07-14-2009, 02:47 AM
killagt's Avatar
Dont buy use, by new. Go to advance auto and buy a new one for around 60 buck, use this coupon for $10 off, I did use it 4 week ago when I bought my window motor.
http://image.advanceauto-email.com/l...0e542975-1.jpg
Old 07-19-2009, 07:58 AM
how difficult is the window motor swap? anything i should know before i attempt it?
Old 07-19-2009, 08:45 AM
Copy & Paste Moderator
VIP1's Avatar
Here is a write-up on replacing the power window motor:
http://shbox.com/page/windowmotor.html
Old 07-19-2009, 09:17 AM
TrybalRage's Avatar
It's really not bad, I did my drivers side in under an hour. Only snag I hit was breaking the little felt-tipped brackets that hold the glass in position at the top of the door.
Old 07-19-2009, 01:38 PM
1badWS6's Avatar
Well if it wasn't done before and they didn't chew the **** out of the holes you should be fine. Whoever replaced the window motor before I had the car fucked it up royally. Oh and those felt tips scratched the **** out of my tint too. So make sure ya got those.
Old 07-19-2009, 02:04 PM
BladeX10's Avatar
Yep. I JUST got my tint done at a shop and as soon as i got home and rolled the window up.. A chunk of the tint was scratched off.. Now i gotta replace the tint on that window once i fix the bracket thing
Old 07-19-2009, 02:33 PM
tbarnard2's Avatar
Do motor and regulator unit........... Fix it once, and get a warranty..
Old 07-19-2009, 05:27 PM
ive had the drivers replaced 2x before this since i got the car in jan 05 the dealership replaced them each time... do you think i still have a warranty of some sort?
Old 07-19-2009, 07:19 PM
killagt's Avatar
it does that to my brand new tint window too, but Im too lazy to do another
Old 07-19-2009, 09:50 PM
Danny2tek's Avatar
we have crappy window motors, get one with a lifetime warranty
Old 07-20-2009, 08:58 AM
99monguse's Avatar
Most GM parts have a 12/12 warranty; meaning 12 months or 12k miles whichever comes first.
Old 07-20-2009, 10:53 AM
Danny2tek's Avatar
not if you buy it from a parts store (Lifetime)
Old 07-21-2009, 12:03 AM
aggiebutter's Avatar
I think my regulator has gone bad because the motor makes noise but doesn't go up or down. Is there a way to just change the regulator?
Old 07-21-2009, 09:17 AM
Save the manuals!
wssix99's Avatar
99.999 % chance your regulator is fine. Check the attachment of the motor to the regulator. Often replacement motors are bolted in, come loose, and disengage the regulator.
Old 07-21-2009, 09:33 PM
jcws6's Avatar
Thumbs up
The problem with the windows on these cars is that both motors don't get the power they need, they way they're wired from the factory. If you typically roll both windows down at the same time, the motors will die sooner than normal.
When I replaced my driver's side motor, I also installed one of these kits: http://www.autotrix.net/Product-Pass...Fix-Kit_1.aspx
The kit is basically a wiring harness that separates the motor circuits. You WILL notice a difference, so I highly recommend it if you've replaced more than one window motor. It's cheap & easy insurance for your motors.
Old 07-21-2009, 10:01 PM
do they make something for the drivers side?? the drivers side motor keeps going out this will be the 3rd time the passenger is the original one never had a problem
Old 07-21-2009, 10:05 PM
jcws6's Avatar
The kit fixes the problem on BOTH sides. It splits the circuit, and each motor gets the right amount of power, so both motors will last longer. You'll be amazed at how fast your windows roll down after you install the kit. Check some of the videos on the site.
