Squeky sounds when decelerating?
Old 07-13-2009, 08:13 PM
hashtagBMW
Speed Density's Avatar
Default Squeky sounds when decelerating?
I don't know if its my clutch or not but If I am in gear and slowing down the car has a constant squeak, almost like a brake squeal but its directly under the car and somewhat near the bellhousing.
It also will make sqeaking sounds with normal driving around 1500rpm or at least thats when I seem to hear it.
Its a stock LS6 clutch from what I understand and my car makes right around 530hp @ flywheel.
Ideas?
Old 07-14-2009, 08:24 AM
Gen414's Avatar
When in gear, and it is squeaking, what happens if you push in teh clutch? Does it go away? Stay there? Could be TOB or PB
Old 07-14-2009, 01:41 PM
hashtagBMW
It goes away when clutch is in or its in neutral. The noise is now in any gear when I am under load and engine braking.
Tony.
Old 07-14-2009, 02:57 PM
Gen414's Avatar
Tony.
If you push in the clutch and it goes away, I would say TOB. Maybe teh PB, but more than likely TOB. But, since you have to pull tranny either way, you can check/replace PB while you are there.
Old 07-14-2009, 05:05 PM
hashtagBMW
It's weird that it just happend though, I took the car to the dyno and sprayed it and now I have a hamster living in my bellhousing.
Quick Reply: Squeky sounds when decelerating?
