A/C Compressor Clutch Swap...Guru's Help...
I have a Sanden 508 compressor. The compressor has 2 "V" groove pulley setup. I would like to swap the clutch/pulley to serpentine, to reuse the compressor. I know the stock balancer pulley is 4 groove (correct???).
Here's the question(s)....1) What clutch/pulley do I need to use to swap this...2) If I have to use a 6 groove compressor pulley, can I use a 4 groove belt on a 6 groove pulley without it tossing the belt?
I bought the Vintage air conversion mount, as I have a Vintage air system, so mounting the compressor is no problem.
This is on my 98 LS1 swap.....
T,
T,
I sent mine here http://members.ebay.com/ws/eBayISAPI...classicautoair I had the same set-up and needed it changed over to serpentine........I'm also running a 6 groove pulley on a 4 groove belt.........No Problem
Ken
Ken
