15*8 only due to the fact someone i know is getting them and they were told they are in fact lighter than real weld prostars....so what is the weight of these wheels???
thanks
thanks
i can weigh the ones i got from you when i get home. i believe they are heavier than the prostars. they are pretty heavy.
I thought the Summits were a couple pounds heavier but not much.
My old Weld prostars with a 275/50 MT Dr weighed a ton more over the GWs and 27x10.5 QTPs I would guess more than 10lbs per wheel heavier.
most of that was probably due to the drag radial being lot heavier than the QTP.
