Brake fluid coming out from front of tranny???
Old 07-15-2009, 10:07 PM
*98TransAm*'s Avatar
Default Brake fluid coming out from front of tranny???
OK i have a rebuilt transmission from Tick, new slave, new tick master, new ls7 clutch,and a remote bleeder. so i pump up the clutch a few times and start bleeding using the remote bleeder. I do that for a little bit and then try to put it in gear(the pedal gets really stiff) and it doesnt really want to so then i get out of the car and look underneath to see brake fluid dripping from the front of the trans where it connects to the bellhousing.WTF???? anybody have any ideas, im 100% sure that the remote bleeder is tight so what the hell is happening? any ideas would be great
Thanks alot
Old 07-16-2009, 01:52 AM
jmd
jmd's Avatar
quick-connect fully seated?
Old 07-16-2009, 07:00 AM
thats something i could check but im almost positive it is, is the part on the slave where the master connects supposed to spin? Anybody else have any ideas?
Old 07-16-2009, 10:53 AM
LS1-450's Avatar
It's coming from some part of the slave plumbing, why not the quick dissconnect? Could also be the "o"-ring seat on the quick dissconnect nipple (held in by the roll pin). Might be a bad "new" slave cylinder as well.
Old 07-16-2009, 11:05 AM
gt eater's Avatar
bad slave cylindar take it back to who ever done the work have them get you a new one!
Old 07-17-2009, 01:08 AM
gmmusclecarman's Avatar
something similar seems to be happening on mine but i think its just extra fluid that came out from when i was bleeding the clutch. the system seems to be holding pressure and fluid so i guess its alright.
Quick Reply: Brake fluid coming out from front of tranny???
