Will a T5 work on a LM7?
Old 07-16-2009, 04:17 AM
RPD_Vette84's Avatar
Default Will a T5 work on a LM7?
i was wondering if itll work and what would be needed? ive seen one guy do it on the v8 rx7 forums.
Old 07-16-2009, 07:24 AM
TTLS1GP's Avatar
yes. there are a few running around here. By yes, I'm referring to TKO5-600's.
I can't remember everypart that is required but a quick search should help you out.
You can use the keisler tranny bellhousing to mate the t5...can't remember the rest!
Old 07-16-2009, 07:57 AM
the_merv's Avatar
The question is if the T5 will hold up..
Old 07-16-2009, 08:47 AM
orange88ls1s-dime's Avatar
the T5 problem usually wont get wrecked from the performance of the engine but from the loose nut with his hand on the shifter even with an aftermarket shifter they are suseptable to burred syncronizers and front main shaft bearing failure since 3rd is an unsupported gear. I personally have destroyed a total of 11 BW T5 trannys and 4 of which were within a one month period. Lots of Fun
Old 07-16-2009, 10:01 AM
the_merv's Avatar
Sounds like it. Lots of people prefer the T56..more stout.
Old 07-16-2009, 12:18 PM
just curious. not planning to beat on the car. just to drive around and the lm7 was just gonna be pretty much stock with a ls1 manifold. so itll maybe be around 300hp or so. im not sure on what it would make.
Old 07-16-2009, 06:31 PM
NemeSS's Avatar
easier to adapt ls1 t56 and will hold more power, etc.
Old 07-17-2009, 03:25 PM
but tryin to find a good t56 for under $900 is kinda hard.
Old 07-17-2009, 03:48 PM
NemeSS's Avatar
i know, i regret sellin the one i had as spare.
but th350 will be cheeper, quicker, and if so need the manual shifting, it can be built in
Old 07-17-2009, 04:58 PM
Dan_W's Avatar
https://ls1tech.com/forums/conversio...ne-t5-ls2.html
Quick Reply: Will a T5 work on a LM7?
