2000 Camaro SS - 30k Miles
Old 07-16-2009, 12:23 PM
SS 2Grand's Avatar
Default 2000 Camaro SS - 30k Miles
Any opinions on what my SS is worth?
2000 Chevrolet Camaro SS
#1518 (of 8912 built for ’00)
30,000 Miles
367 rwhp/418 rwtq (Approx. 433 fwhp/493 fwtq)
Pictures can be found here...
http://imageevent.com/ronk/ss?pa=h9JN4ca
Standard Equipment:
• Automatic 4-speed
• Power 4-Wheel Disc Brakes
• Power Rack & Pinion Steering
• Driver & Front Passenger Air Bags
• Pass-Key II Theft Deterrent Alarm System with Starter Interrupt
• Daytime Running Lamps
• Black Roof and Body Color Mirrors
• Air Conditioning
• Folding Rear Seat
• Full Analog Gauge Cluster
• Full Center Console
• Four-Cup Holders
• Intermittent Wiper System
• LH & RH Covered Visor Mirrors
• Rear Cargo Closeout Panel
• Solar Ray Tinted Glass
Factory Options:
• Auburn High-Torque Performance Differential
• SLP Dual/Dual Exhaust
• Monsoon Stereo System (8-Speakers) with Amplifier, Cassette and Remote 12-Disc CD Changer
• Cruise Control
• Remote Hatch Release
• Fog Lamps
• Power Door Locks
• Power Windows
• Power Side Mirrors
• Auto Dimming Rearview Mirror
• Leather Seats
• Leather Wrapped Steering Wheel w/Radio Controls
• Remote Keyless Entry
• Carpeted Rear Floor Mats
• Body Side Moldings
• 6-Way Power Driver’s Seat
• SS Performance/Appearance Package
• Acceleration Slip Regulation
• Rear Window Defogger
Modifications:
• 3.23 Gears
• Precision Vigilante 3200 Stall Torque Converter
• Transgo Shift Kit 4L60 Trans
• B & M Transmission Super Cooler
• Comp Cams 222/222 .563/.563 114lsa Camshaft w/ Springs and Pushrods
• Dyno Tuning
• LS6 Cold Air Intake
• Direct Flow Air Lid
• Granatelli Mass Air Flow Sensor
• Ported Throttle Body
• Fast Toys Ram Air Kit
• SLP Bellows
• SLP Long Tube headers w/Random Tech High Flow Cats
• SLP Y-Pipe
• Dynomax Ultra Flo Muffler
• Quick Time Electric Exhaust Cutout (Zed-style)
• Hypertech 160 Degree Powerstat
• MSD Plugs and Wires
• Nitto NT Extreme 555R Drag Radials
• ASP Underdrive Crank Pulley
• BMR Lowering Springs (1”)
• BMR Relocation Brackets
• BMR Sub-Frame Connectors
• BMR Lower Control Arms
• BMR Strut Tower Brace
• BMR Panhard Bar
• Energy Suspension Trans Mount
• Chrome SS rims (17"x11" out back)
• SS Floor Mats
• SS Personalized Deck Lid Mat
• SS Grille
• Automatic Billet SS Shift ****
• Camaro SS #1518 Dash Plaque
• New Battery (June ’09)
The car was $30,000 brand new, full loaded from the factory and has over $10,000 in modifications. The car is in spectacular condition…exterior paint, interior leather and dash etc. Car has been garage kept since purchased new in November ’99.
The engine is in need of a dyno tune to dial the idle in. At very hard stops or when you jab the throttle hard and let off the gas quickly, the idle tends to surge then drop down quickly. If this happens, I just drop it in Neutral and the idle stabilizes. This can be a minor nuisance from time to time, but is easily fixed with a dyno tune. A typical dyno tune runs no more than $500, and I plan to reflect this in the sale price.
The chrome SS rims need a good buffing to get rid of some small rust spots. As you can see from the pictures, the chrome rims still look great, but when you get up close they need a bit of elbow grease to clean them up. I’d say thay are in better than good condition, but not near perfect as the rest of the car is.
Old 07-16-2009, 02:19 PM
j0n
j0n's Avatar
If you pay the money for a good tune you'll be able to get much more than you'll get without it. With the good tune it will run perfectly and also post higher hp/tq numbers, enticing more buyers. Also, with a car that is close to perfect, an imperfect tune implies that something is wrong with the combination, perhaps that it is very hard or even impossible to tune it as it sits.
Old 07-16-2009, 02:32 PM
SS 2Grand's Avatar
i hear ya. it's actually been through two dyno tunes in 10 years and after awhile, the same problem begins to occur. it will run fine for awhile, but then the surging begins. both tunes were done at speed inc. the dyno numbers were pulled when it was running good, so i don't think those would go up any.
or, i could not mention a thing and when someone comes to test drive it, hope it doesn't happen!
any thoughts on a price without the idle issue?
Old 07-17-2009, 12:44 AM
ws6killer's Avatar
it sounds like it has to much base air flow man.
Old 07-17-2009, 08:23 AM
SS 2Grand's Avatar
from the fast toys ram air kit maybe? that draws air from under the front of the car and it's sealed.
Old 08-15-2009, 01:04 PM
SS 2Grand's Avatar
i installed the block off plate to disable the ram air and took it for a spin today. i went into a parking lot and did about 10 very hard stops and while the idle did dip down below 500rpms, it never stalled out. drove it around on the streets for about 20 minutes and didn't have to drop it in neutral once. i think that may have solved my idle issue. thanks!
any other input on what my ss is worth?
Old 08-21-2009, 03:14 AM
ls2supersport's Avatar
would you take 15k for it?
Old 08-21-2009, 10:00 AM
SS 2Grand's Avatar
to be honest, i haven't posted it online anywhere yet, so i'm not sure what 'the market' would think its worth at this point? where i sit today, $15k would be the very lowest i'd consider selling it for if i had no bites at a higher price after it being online for awhile. i was considering posting it at $19,500 to see if it brought any interest and if it doesn't, i'll know i'm too high.
Quick Reply: 2000 Camaro SS - 30k Miles
