Boost leak (STS) help
Okay guys I am back with more questions I have my STS 67mm up and running with a W2A intercooler. My problem is my wastegate is opening and closing constantly during full boost (doesn't matter how much boost). I took down all the pipes and reinstalled them tight as a crickets a$$hole and still does it. I am currently replacing the spark plugs. Does anyone have any input on what it could be or had this problem before?
What are you using to reference your wastegete? where is the vacuum source coming from?
And is that with the AEM Tru boost hooked up or running off the WG spring? Does it do it if you just run off of the spring?
