Got some used Konis, what hardware do I need?
Old 07-18-2009, 03:25 PM
TireSm0ke's Avatar
Default Got some used Konis, what hardware do I need?
I just picked up a front set of Konis, they might be used but either way they came without any hardware. What am I missing? Ive heard theres a washer I need to use?
Old 07-18-2009, 03:44 PM
99Bluz28's Avatar
Do you have these, for each shock?
Bayonet mount nut, metal lower spring seat and plastic spring indexing seat, snap ring in lower spring seat mount grove, Koni bump stop on shock shaft, large washer 1/8" thick, with a 3/8" or 7/16" hole ?, and it's 2-1/8" diameter.
For the lower shock mounts just reuse the factory mounting hardware.
Old 07-18-2009, 06:56 PM
Major_Lee_Slow's Avatar
I'd recommed sending them to Koni for a rebuild. It's cheep insurance to insure that they are good before doing the install.
Old 07-18-2009, 11:26 PM
TireSm0ke's Avatar
Do you mean move the stock bump stops to the Konis? Or do they come with their own bumpstops? I found a washer thats 3/8 but its about 1 1/2 in diameter. Will this work? And should I just use the stock nut on top of it? Thanks
