Anyone using 4000+ stall on street? (Lock up)
Well Just sent off converter to TCI for stall adjustment to try and break 10's natural in street trim.
Current converter is 3-3500 street fighter.
Anyone using a higher stall on street? How bad is it?
Thanks for help.
Thanks for help.
Originally Posted by theblur98ss
I'm using a yank pt4000 on my 422 that sees alot of street driving. I don't seem to notice any troubles with it. I never had another auto setup to compare it to though.
Originally Posted by BigPlanTransAm
wow, i have a ~3200 and even though its much less noticeable now than when i got it, i dont know how you could drive a 4000+ and enjoy it.
Yeah, setting the part throttle shifts higher, tweaking the lockup points a bit, and running numerically higher gears go a LOOOOOOOOOOoooooooooong way towards making a loose converter more livable on the street.
"A quiet exhaust is a plus too."
Oh, no doubt. I have the stock muffler. I wouldn't like this stall with my old B&B Tri-flo. I used to have a TP4600 (ONE LOOSE BASTARD!) with that exhaust on my '00 and it was a pain to drive on a daily basis.
Thanks Guys,
Pewter Seems to have closest to what I am getting.
Pewter, you drive to track right?
So would you say to not be scared of the 4200?
I have heard great things about Yanks Tightness but I already had this one.
Restricted User
I drive to and from the track. No issues and hills aren't a problem. I wouldn't be afraid of it. A loud exhaust does get old quick though... I also have 3.73 gears so that makes the converter feel a little tighter. Traction is my only real problem.
Well I have 3.73's as well, Mufflex with flomaster is pretty livable. I should install a manual lock switch as well for converter.
Traction is going to be my downfall right now to , 26 x 10 ET streets seen all they could handle - Should have went with the 11".
I'll sell you a set of used ET Drags. 26x10x15. There is still a lot of good rubber left. Even with my John Force burnouts
Though I plant to get some Convo Pros soon as money permits - hmmm could be never.
As far as converter, When they call and tell me they recieved I think I will tell them make it 4200 or maybe 4000..Just not sure.
Although 2002silver said that you have no problems with yours @ 4400.
I also wonder if I back timing off around part throttle/lower load areas to lessen torque if it will help the situation?
