Are all Fikse FM5s, 3 piece? a few more fikse questions inside...
I bought a used set of Fikse FM5s, and the previous owner told me that they are a 3 piece wheel. But after looking at them, they appear to be 2 pieces...I'm not sure though. If I take off the bolts behind the face. How do the pieces break off. The hoop, lip, and face? Also, is there a way to take the center section off to get powdercoated, with out taking the tire off?
Thanks for the help
Patrick.
Thanks for the help
Patrick.
LS1Tech Co-Founder
Newbie to nice wheels eh?
ALL Fikse wheels are 3-piece. The bolts hold all three pieces together. Front hoop, rear hoop, center. To remove the center, let the air out and remove the bolts. Use some clamps to hold the hoops together afterwards. This works 90% of the time, but sometimes the tire is strong enough to push the hoops apart, requiring a reseal inside.
Make sure your powdercoater knows what he is doing. Overheating the aluminum can change the metallic properties of metal and weaken the wheels.
Patrick.
It takes some work man it's not just a matter of unbolting the center, powder coating it and bolting it back together. You can try that route but more than likely the seal between the two barrels may "break" and then you will have to deal with leaks. If you want to do it right one time have the tires taken off, take the wheels apart, get the centers coated then follow the video to put everything back together and you should have a leak free wheel.
Remember this is just another option since you mentioned you could send them back to Fikse and let them handle it but I'm assuming you are going to have the tires taken off anyways before you send the wheels?
