Would 275/60/15 tires slow me down?
Old 07-19-2009, 11:01 PM
Formula_LS1's Avatar
Default Would 275/60/15 tires slow me down?
This would be on an automatic car with 3.42's. I'd be going with ET Streets on a 15x8 drag wheel. I'm currently running Nitto drag radials on stock wheels. Thanks for the help.
Old 07-19-2009, 11:11 PM
Also, how would they fit (I'm not lowered)? Thanks.
Old 07-21-2009, 09:26 AM
master of the "jack"stand
ChevyWeatherman's Avatar
I don't think it would slow you down at all. You should hook better if anything.
Old 07-21-2009, 09:57 AM
ndfrsd6's Avatar
just wondering why a 28 in tire .....are you spraying or bolt on only ? little more info please
Old 07-21-2009, 10:35 AM
Camaro396's Avatar
They probably will slow you down with that gear, for sure. Unless you're spraying like a 400 shot.
Old 07-21-2009, 12:22 PM
pozesd99''s Avatar
just run a 26 in tire unless your getting gears or something lol
Old 07-22-2009, 03:39 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
It's worth doing if you can't hook 26's. What do you run now? You can lose 1-2 mph and a tenth or two if you already hook good on 26's.
Old 07-22-2009, 05:23 PM
02white6.0's Avatar
All depends on how much power your making with that tall of a tires and 3.42s, mine were perfect with 4.10 in a 400rwhp n/a A3 car. All depends on the setup, now that im back to an M6 I dont need the 28s unless on spray.
