how much timing
Old 07-20-2009, 09:32 AM
10secZ28's Avatar
Default how much timing
what kind of timing do you guys usually run on a 250 hit? im at 19 on race gas and i think its iffy
Old 07-20-2009, 09:55 AM
ShiznityZ28's Avatar
we pull 11 for a 250 our base is higher than most. 18-19 is a good start.
I see your in Belair. give us a shout if you need some help track tunning that thing.
Old 07-20-2009, 09:58 AM
10secZ28's Avatar
hey thanks man, i used to deal with jeff a while back, i have matts old car..... ive met you a couple times. I just wasent sure if i should back off a couple more degrees
Old 07-20-2009, 10:03 AM
ATVracr's Avatar
What does it run? N/A and on spray?
Cold plug and race gas will help you with a bigger tuning window.
Old 07-20-2009, 10:05 AM
Mike@HSW's Avatar
ya whats the timing on the motor. Id start by pulling 11-12 and going from there. Since your running straight race gas and depending on your plug, you'll probably be adding back a bit more.
Old 07-20-2009, 10:09 AM
10secZ28's Avatar
we just put the car back together this year so we are hoping to make some passes at capital this fri, the dyno we put the car on i think was a little happy but it made 480 to the wheels on the motor and 765 on the bottle.... that just seems a little high to me
Old 07-20-2009, 10:10 AM
10secZ28's Avatar
mike it has 19 degrees in it now and the plugs are # 8
Old 07-20-2009, 10:12 AM
10secZ28's Avatar
sorry i misunderstood you, im not exactly sure how much time we had in it n/a
Old 07-20-2009, 10:16 AM
ATVracr's Avatar
I'd pull 2* more from your dyno tune ...a 2 or 3 second dyno pull builds alot less heat than a 9-10 second pass down the track.
Pump gas?
Old 07-20-2009, 10:18 AM
10secZ28's Avatar
thats more or less what i was thinking, and no it will see only race gas on the spray for the most part
Old 07-20-2009, 10:25 AM
ATVracr's Avatar
Good deal.
Make a 1/8th mile hit or 2 and check the plugs out.
Since you cant adjust the cyl. timing like we can get yourself a set of tr9's and if you have a hot cyl. stick one in there it will help.
Good luck!
Post up you have any other questions.
Old 07-20-2009, 10:36 AM
10secZ28's Avatar
thanks man i appreciate it, it went some 10.00s last year on a 150 hit so im hoping on a 250 it could see some 9.50s or 60's, and last year it had a stock maf, tb, and an ls6 intake, this year we swapped in a 92mm tb and a vic jr
Old 07-20-2009, 11:59 AM
We don't deal with jeff anymore...
Old 07-20-2009, 12:01 PM
250 on a 370 should go low 9's for sure.
Old 07-20-2009, 12:02 PM
10secZ28's Avatar
haha so ive heard..... ive been workin with jason alot
Old 07-20-2009, 07:58 PM
WE TODD DID's Avatar
Timing on motor doesn't have a thing to do with the timing on the spray. If his engine likes 40* of timng, and he pulls 12, he would be spraying 250 on 28* of timing. That won't work.
One of my personal vehicles, runs at 35* total on motor, and on a 175, I back it down to 18* total. On both systems, it is at 5* total. That is what the engine likes.
Old 07-20-2009, 08:21 PM
camscam02's Avatar
19 seems like an awful lot to me. I guess check your plugs and got from there. I would think around 15 would be in the ball park area.
good luck.
Old 07-21-2009, 07:23 AM
What cam do you have in it. It would be hard for ti to work well with a ls6 and vic jr. you need 8( or more) degrees more exhaust on that jr with nitrous than the 6. Hit me with a PM if you want.
Old 07-21-2009, 07:26 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Only run as much timing as needed, checking plugs and putting the best gas in def helps that window. Unfortunately it maybe too late if you chance it. I'd start progressively and go up 1 deg at a time until the plugs tell you to stop or show what is optinum.
