What intake is everyone running with big boost?
Old 07-20-2009, 10:24 AM
XLR8N's Avatar
Default What intake is everyone running with big boost?
How many guys here are still running a factory style intake? and how many are running a cast intake? what are the pros/cons of either?
Old 07-20-2009, 11:33 AM
dschmittie1's Avatar
I think it depends on what your goals are. Most guys that are either running Stock intakes or running something line the Vic JR. Unless it is a high $ setup then they might be running something bigger. But Hell Fireball is running an as cast Super vic with his car and is going low 8s right now.
PS I am still running my stock LS6 intake and the car just went 10.6@133mph in the heat over the weekend.
Old 07-20-2009, 12:04 PM
XLR8N's Avatar
how much boost can the ls6's handle?
Old 07-20-2009, 12:07 PM
dlandsvZ28's Avatar
KP who makes it look easy to run low 9's I think was running a stock manifold also.
Old 07-20-2009, 12:08 PM
AFASTYZFR1's Avatar
I run 16psi on LS6 intake
Old 07-20-2009, 12:13 PM
Yeah I am 13 psi in a stock ls6 intake right now.
Old 07-20-2009, 12:16 PM
speedracer5532's Avatar
I have ran 18.5 psi with a FAST.
Old 07-20-2009, 12:27 PM
'Trust''s Avatar
19-20 psi, Vic Jr. and intakelbows.com elbow:
Old 07-20-2009, 12:47 PM
LS1RedZ's Avatar
Im running the LS6 @ 11psi.
Old 07-20-2009, 03:04 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,088 Likes on 716 Posts
LS6 and LS2 to 21.5 and 25 psi respectively....
Old 07-20-2009, 03:27 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I think I'm the only person to have blown up an LS6 manifold under boost. I was only running 16ish psi, so I very seriously doubt that the manifold blew up due only to the boost since so many others have ran so much more than me thru factory composite manifolds...
Old 07-20-2009, 03:52 PM
sparkwirez06's Avatar
I used the vic jr. to pick up room in the front and back of the engine. also heard enough about the #7 going lean.
http://www.turbols6.com/gallery/TYPHOON-LSX-TURBO/avb
Old 07-20-2009, 05:42 PM
T/A KID's Avatar
Trust how many RPMs do you spin on the motor?
Old 07-20-2009, 05:58 PM
hawk584's Avatar
stock LT1 intake... what's considered low boost?
Old 07-20-2009, 08:54 PM
'Trust''s Avatar
Peaks at 6300 shifts at 6500, the Vic Jr didn't add and power but it carries it quite a bit longer now.
Old 07-20-2009, 09:57 PM
deathbydisplacement's Avatar
i would also be worried about the number 7 cylinder going lean on stock manifolds
Old 07-21-2009, 06:15 AM
Fireball's Avatar
like dschmittie1 said, I'm running the super victor with a wilson 90mm elbow. shifting 8000-8500 rpm. 30psi boost
Old 07-21-2009, 09:24 AM
elias_799's Avatar
does the vic junior actually help with the #7 cylinder going lean ? i thought it was all about the block. i believe the ls1 did not have a coolant passage on the back of the block beside the #7 cylinder. and the ls6 block does.
Old 07-21-2009, 09:28 AM
ChevyChad's Avatar
The factory manifold has nothing to do with the lean #7 issue. I forgot who, but someone turned the manifold around completely facing backwards, and the rear cylinders were still leaner. Do a search in here if you wanna find out who..
Old 07-22-2009, 08:06 AM
WAHUSKER's Avatar
I remember that thread, very informative. Still wondering if the LS6 coolant bypass mod contributed?
But I ran 13-15 psi w/D1 on a FAST 78, popped the burst panel once when the coils were backwards & it backfired, but other than that had no issues up to 6500.
I'm now running a Vic Jr with an elbows.com elbow (for the increased flow) at 14-16 psi on the F1 up to 7k.
