underdrive pulley question
im going to be putting an underdrive pully on my camaro. and from what i can see it doesnt look to difficult. i just wanted to know if there was any tricks or any difficulties i should be aware of.
When you pull the old pulley off stick a 6" 3/8 extension in the crank and have the puller end sit in the end of the extension. Also make sure you have a longer crank bolt so you can pull the new pulley onto the crank with it.
