Whats the cheapest piston for a 2000 block that has been honed?
Old 07-20-2009, 01:23 PM
Stryker's Avatar
Default Whats the cheapest piston for a 2000 block that has been honed?
Im dropping my 2000 ls1 block off to the machine shop to be cleaned up and honed since its set in my shop and the sleeves have rusted a bit from the moisture i need to find a cheap set of pistons for whatever it ends up they hone out too hopefully not past the 3.910. Any ideas?
Old 07-20-2009, 02:09 PM
Shawn @ VA Speed's Avatar
Mahle are the cheapest
Old 07-20-2009, 05:13 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
We've got a set of Diamond's on special for crazy cheap that will work great if you're going back with a 6.125" rod. They are a 2cc valve relief flat-top piston.
https://ls1tech.com/forums/sponsor-s...xas-speed.html
Let us know if we can help!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
