Cold side piping material
Old 07-20-2009, 03:20 PM
bbaCJ8's Avatar
Default Cold side piping material
I see that most people with turbo setups are running aluminum piping for their cold side....why? Weight? Thermal properties? Corrosion resistance?
I'm working on a custom setup and it'd be a lot easier for me to run mild or stainless steel so I can cut and weld as needed. Is there any real downfall to using steel instead of aluminum? Search didn't turn up anything useful.
Old 07-20-2009, 03:59 PM
Tricked-Out-Toy's Avatar
weight is the main thing. 4" mild steel is HEAVY!
Old 07-20-2009, 04:03 PM
bbaCJ8's Avatar
So is a Jeep Scrambler on 41" tires
I'll have 3" piping to and from the intercooler and will use as little as possible, so weight won't be a huge concern for me. Just wanted to make sure there wasn't another reason I was missing.
Old 07-20-2009, 04:16 PM
Johnv's Avatar
I used some mild steel on mine for same reasons, I had the gear to weld mild myself, but not ali.
I had the pipes done in a thermal coating when done, they came up great and no worries about rust or corrosion.
Old 07-20-2009, 06:12 PM
6techniques's Avatar
All the above
if weight isnt an issue then go for it. or just set your machine up for aluminum if possible.
answers above
Old 07-20-2009, 10:01 PM
deathbydisplacement's Avatar
aluminum, all around better than mild steel. cools of quicker also
Quick Reply: Cold side piping material
