moser 12 and soild pinion spacer
Old 07-20-2009, 08:38 PM
silverLSWON's Avatar
Default moser 12 and soild pinion spacer
i am getting ready to swap out motive 4.56 gears to motive 4.10's. i will putting in all new pinion and carrier bearings and i was wondering if i should just install a solid pinion spacer. i don't know if alot of people have done this with a moser 12 bolt or not. i tried a search but i didn't find to many threads about it. let me know what you think or if you have had good or bad luck with one.
Old 07-20-2009, 08:45 PM
jetlag's Avatar
It takes a little more time to setup, but well worth it!
Old 07-20-2009, 11:15 PM
rpmauto's Avatar
my strange 12 bolt had one in it with the 3.73s, i would have reused it, but i didnt have any shims and when they put it together they screwed one up pretty bad. So i just used a crush sleeve. Plus i would assume you should have a pinion depth checking tool to properly set it up and i dont have one.
Old 07-21-2009, 06:46 PM
i was going to install everything with a new crush sleeve and then disassemble it, then mic the crush sleeve and try to shim it as close as i can to it. i will check the pinion depth as well. i just think that would be the best way IMO.
Old 07-21-2009, 10:24 PM
rpmauto's Avatar
let me know how that goes. I may try it
Old 07-21-2009, 10:54 PM
jcws6's Avatar
That's not the recommended way to do it. Crush sleeves work by putting tension on the pinion, and a solid spacer uses a specific torque on the pinion nut. The best way to fit it properly is to use a pinion spacing tool and follow the directions that came with the spacer. I've used one before, and I had pretty good results.
Old 07-23-2009, 12:07 AM
1BADAIR's Avatar
just play with the shims until the turning torque is right.
not hard to do and highly recommended with a 6 speed
Old 07-23-2009, 03:51 PM
i have an m6, kinda why i want to try the solid spacer
