wet nozzle questions
Is the nozzle position on a wet kit a big deal. I use to have a dry kit and it seemed like where you put your nozzle made a big difference. I understand that a wet goes after the maf, but just didnt no if it mattered much after that?
also I put my nozzle in my bellow and it seems like Its got a slant to it where when i spray it, itd probably hit the side of the throttle body, but i cant get it to spray straight its like the lines push it that way. So im wondering how you all setup your nozzles to hold up straight, besides using a plate.
sorry for the newb questions.
yeah, thats what i figured. Im just needing help on getting it mounted right, cuz i cant fix it from turning. does everyone use those bolts that go onto the nozzle and then one goes onto the other side to hold it in place? I figured if I could find a way to loose that it may work better idk.
