General Maintenance & Repairs - SES Light WTF
DoomSlayer
07-21-2009, 07:12 PM
Anyone know of an override for the SES light? Im tired of the thing coming on every week or two and would like to get rid of it once and for all. Any suggestions?
LS6427
07-21-2009, 08:41 PM
You need it for when its something more serious.
If you're bone stock its most likely the EGR crap. Tear all that shit out of their anyway.
DoomSlayer
07-21-2009, 09:05 PM
Yup im stock... I can disconnect battery and it will stay off for around 2 to 3 weeks and then just pop back on.
ghardester
07-21-2009, 09:09 PM
You can buy a code reader that will let you know why the light is on and let you turn the light off, for under $100. Plugs in under the dash.
You really should read the code so you can decide if you want to ignore the light.
LS6427
07-21-2009, 09:52 PM
Thats because disconnecting the battery resets the PCM and clears codes.
YOu have something wrong. Go tomorrow, get a free scan at an auto parts store and let us know tomorrow what the code is.
And no matter what the code is...DO NOT buy anything from them to fix it, just report back here first.
Later.
DoomSlayer
07-26-2009, 10:42 PM
Going to go to the Autozone tomorrow and get the code... will report in tomorrow thanks guys...
DoomSlayer
07-27-2009, 01:23 PM
Ok the code was P0704 which is a clutch switch circuit failure... probable causes Failed clutch switch or open or short circuit condition.
Explanation: Vehicle speed went from 0 to 24 MPH and back to 0 MPH with no clutch switch change.
Anybody seen this one before?
DoomSlayer
07-27-2009, 01:32 PM
Ok did some researching on the forum... found a guy with the same code and possible fixes. One of the tech guys asked if the cruise control works? Mine hasnt worked since I bought the car a few months ago... here is what he said...
"mine threw that code and the gm guys said it could be anything from a switch all the way up to the ecu. i did some looking and found out that it is a little switch mounted close to where your master cyl connects to the clutch petal, i screwed it in because it appeared to be not making contact with the petal. after i tried that, my cruise worked and it did not throw the code again.
hope that helped"
Anybody got a pic or a better understanding of where the switch is?
DoomSlayer
07-27-2009, 06:07 PM
ttt????
junkindatrunkmx6
07-27-2009, 06:50 PM
It's on the left hand side of your clutch/brake bracket. Try google images for a pic of what it looks like.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
