Nitrous set up
Old 11-17-2003, 09:20 PM
CLB3RD's Avatar
Default Nitrous set up
Im running 12.8 on motor with no internal engine mods...no long tubes on street tires....what would be the highest dry shot i could run without messing with fuel pumps and injectors?
Old 11-17-2003, 09:22 PM
EVIL's Avatar
you will hear 100 from some and 150 from some. i wouldnt go more than 100.
Old 11-17-2003, 09:23 PM
CLB3RD's Avatar
im running 12.8's around what could i expect on a 100 shot?
Old 11-17-2003, 09:24 PM
EVIL's Avatar
mid 11's probably.
you m6 or a4?
Old 11-17-2003, 09:26 PM
CLB3RD's Avatar
i have an a4
Old 11-17-2003, 09:27 PM
CLB3RD's Avatar
with my stock rearend and 2.73 would u think it would be ok to spray off the line on tires
Old 11-17-2003, 09:35 PM
EVIL's Avatar
my buddy has a cam only a4 that ran 12.1's and on a 100 shot spraying somewhere during the 60 foot ran a 11.40 with the shifts all messed up. now hes running 11.7's with the same mods and better shifts, so were hoping to run 10's on a 100 shot.
Old 11-17-2003, 09:44 PM
CLB3RD's Avatar
so what do u think about spraying off the line....should i worry about my rearend?
Old 11-17-2003, 11:26 PM
koolrayz's Avatar
Look at my sig. I have the stock fuel system and manifolds. I run about where you do on motor and it looks like we have simular setups with what little youve told us about your car. I see your new to the board , you should add all your mods to a post like this or better yet make a signature that shows your mods. How your rearend holds up has as much to do with what tires you use as spraying out of the hole. IMHO I spray out of the hole with slicks on a stock 2.73 rearend. How long it holds up is hit or miss.
Old 11-18-2003, 02:13 PM
CLB3RD's Avatar
alright thanks man and ill make that signature and mod list
