No OD after shift kit install
After doing a transgo hd2 (minus the 2-4 servo on the outside) it seems like the tranny is a real dog. Plus, it won't give me overdrive. It seems to be in 4th gear but I'm running 2500 RPM at 55MPH with 3.23s.
Also, if i manually put it in 1st gear, it won't roll, then when i give it some gas it seems to "break loose" and start rolling. By manually shifting it shifts great, chirps tires, etc. But i still have no OD. Which is pretty important when you live 40 highway miles from the track and DD the car.
Any insight fellas and ladies?
On a side note, i did the 3 spacers for shift firmness, followed the instructions to the letter, and double checked it all twice.
Also does not downshift automatically, when doing 55-70 and I go WOT, it doesn't downshift like it used to. I'm trying to think of any other info I could give. I drilled out the holes in the separator plate to the larger of the two specs.
I still have torque management engaged (never had it tuned).
The not rolling in manual first gear is the only definitive issue i can see, If i give it just a tap of gas it "breaks loose" and rolls fine, but if i shift it back to reverse or park and then back to drive, it doesn't roll. If i put it in D it moves fine but seems sluggish. It seems like something is "stuck".
I'm really tempted to take it to a shop and say "fix it" but then I'm afraid I'm looking at hundreds of bucks to fix some stupid spring or whatnot.
So you didn't touch the 2-4 servo??? Why not? Did you put the VB bolts in exactly where they came out? Since you obviously missed something during the install, I would take it back out and double check again. Remember 2 of the springs are white so make sure you didn't get them mixed up. Also, 3 spacers in the 1-2 seems is alittle much IMO. I used 1 and have a 3000stall. Shifts plenty hard but not parts breaking harsh.
LS1Tech Sponsor
I would check the 1-2 and 3-4 acumulators, Missing accum pin possible causing the band to always be applied.in particular the 4th accum as if applied through that circuit you could really only create 2nd and 4th gear . and manual 1 would be like brakes applied. The pin may have fallen out during assembly. You will need to remove vb to see .
__________________
Okay, i'm an idiot and feel stupid. I dropped the pan and filter and started undoing the wiring, and someone had conveniently unhook one connector already. The male end was in the female end but not "clicked". I attached it, hooked it all up and it's beautiful. With TM still active, my shifts are awesome. 3 spacers is not bad at all (maybe i'll think again when i get TM off). At the track just now it kicked the rear out a little on the 1-2 shift. Loving this kit.
Thank you to everyone who tried to help. Commence pointing and laughing.
I double checked the bolts ten times but the wiring harness I figured was click and done....i just didnt do the click part.
Oh well, better that than some mystery problem that takes days and hundreds of dollars to fix.
