Stereo & Electronics - fog light and headlight problem
View Full Version : fog light and headlight problem
therobman
07-22-2009, 02:12 PM
my fog lights dont turn on neither of them do, the switch doesnt even light up. i checked the fuses, changed the switch, and swapped the fog lamp relay and nothing am i missing something. also my left t/a headlight doesnt go up, it doesnt make and grinding noise and i dont even hear the motor turn, but the headlight goes on but doesnt come up. this all happened after i moved my fuse boxes under the hood because i dropped something and the red cap that comes the big + fell off and it touched the frame and sparked really quick
Havoc54
07-22-2009, 03:18 PM
So you changed out the switch to turn them on inside and put a new fog light fuse in the fuse box under the hood correct?
WhiteBird00
07-22-2009, 03:48 PM
There is no fog light fuse under the hood... in fact, there is no fog light fuse. The fog lights are protected by the TAIL LPS fuse in the dash fuse panel. If that is okay (test it, don't just inspect visually) then the next step is to test for power at the relay socket in junction box #1 under the hood. The brown wire at the relay should have power whenever the parking lights or headlights are on. The yellow wire should have power when the lights are on and the fog light switch is on.
BTW, you don't have the high beam headlights on? The fog lights don't work with the high beams.
therobman
07-22-2009, 03:55 PM
well fixed the headlight problem i unpluged the big connector for the headlight and sure enough all the prongs were corroded. just sprayed some rust crap let it sit blew it out with some air and its works perfect now. still stumped on the fogs though
therobman
07-22-2009, 03:58 PM
yea i changed the switch and i switched the realys and nothing. yes my highbeams arent on im going to test that fuse and test those connections the switch doesnt even light up so somewhere its not getting power
WhiteBird00
07-22-2009, 04:38 PM
The Firebird fog light switch powers its ON indicator light from the output side of the relay under the hood - it's not just an indicator of power getting to the switch. So the indicator light not working doesn't help with diagnosing the problem at all. The indicator light in the switch doesn't light up because the fog lights aren't on... something we already knew.
therobman
07-22-2009, 06:02 PM
o ok yea i checked the fuse and the relay again they are both good
therobman
07-23-2009, 12:11 PM
anyone else have any ideas
WhiteBird00
07-23-2009, 12:37 PM
Did you check the wires at the relay as suggested? If so, what did you find?
therobman
07-23-2009, 03:38 PM
na i was gunna check it today but its ranning here just wondering if anyone else had any thoughts
