Line Lock setup pictues needed ! ! !
Old 07-22-2009, 06:50 PM
Pate_2008's Avatar
Default Line Lock setup pictues needed ! ! !
I am going to be getting ride of the big ugly abs box and hooking up my line lock soon and wanted some pictues of what some other guys did if you had some for me i would really appricate it. Thanks
Old 07-22-2009, 10:46 PM
SJM Manufacturing Inc's Avatar
These are our kits.
The base kit starts at 139.99 including the adjustable wilwood proportioning valve, preformed lines and every fitting you need.
If you want something custom, we can provide you with any fitting or component you need. Designing your own kit will have a sense of accomplishment but do not do it from a cost perspective. The valve alone will set you back ~55.00…you'll need quite a bit more to complete the setup.
Old 07-23-2009, 07:57 PM
blackls1ta00's Avatar
Default heres my sjm kit with abs delete,didnt get all of the solenoid
Old 07-23-2009, 08:02 PM
jetlag's Avatar
Yeah that's what mine looks like ^
SJM kit is nice.
Quick Reply: Line Lock setup pictues needed ! ! !
