oil pump bolt in pan.
Old 07-22-2009, 07:27 PM
SSmoken's Avatar
Default oil pump bolt in pan.
Magnets don't work. What now?
Old 07-22-2009, 07:51 PM
crainholio's Avatar
Easy procedure:
1.) Kick self.
2.) Remove pan.
You might have better luck with a small magnet on string, fish it around the front of the pan with a flexible rod like a long zip-tie.
Old 07-22-2009, 08:05 PM
00fastta's Avatar
Looks like the motor is coming out...
Old 07-22-2009, 08:15 PM
SSmoken's Avatar
Well we eventually got it out. Things aren't going well getting it back in. Whoever designed this needs their face broken.
Old 07-22-2009, 09:07 PM
TA1364's Avatar
Relax and take your time, make sure its right.
Old 07-22-2009, 09:24 PM
Tough Mudder
Hilton's Avatar
You can drop the pan a little. That'll help a lot. It's not that big of a deal. Tighten the bolts back up in the right sequence ~18lbs and you probably won't have leaks. Don't forget the bolts from the bellhousing.
Old 07-22-2009, 11:25 PM
SSmoken's Avatar
Pan was already dropped. Had to beat around on pan to figure out where it was. Once we located it we dug around with mAgnets for a while. First time we put it together there want an issue and my skinny fingers got it. Not this time lol. Oh well cars going now finally.
