Suspension & Brakes - 95 different than 02?
Pavetim
07-23-2009, 12:22 AM
Is my suspension on my 95 firebird different than on a 02 firebird? I need to look into it more but just bought a project car and it seems the pass front tire is almost 2 inches farther back than the driver. Said the car was in accident so have to look into it more. but was wondering cause if the suspension is damaged i'll just put on a suspension from a 98-02. Thanks.
99Bluz28
07-23-2009, 01:18 AM
Take a look at the front passenger side lower control arm mount bolt/nut position in the caster adjustment slot, which is the rear mount point. Now compare it to the drivers side.
FYI, if the caster is set low the wheel will be farther back in the wheel well.
mitchntx
07-23-2009, 06:39 AM
bent knuckle ... common occurence for these cars after an accident.
BMR Tech2
07-23-2009, 07:43 AM
The brakes from the 98-02 are different but the a arms are the same. The k member has different engine mounts but the 02 parts will fit the 93-97 car. If you want to upgrade to aftermarket parts give me a call. We have several packages that might interest you.
UMI Sales
07-23-2009, 07:58 AM
Hello
I am not sure if you are looking to use OEM parts or go with aftermarket parts. But I just wanted to leave you know that UMI Performance offers a wide variety of front end suspension kits. Below is a link to show you what all we have too offer!
http://www.umiperformance.com/catalog/index.php?main_page=index&cPath=7_137_96&zenid=d5io3eb64sc2oepirfpnh7tr47
If you have any other questions feel free to ask and I will be more than glad to help.
Thanks
Brad :drive:
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
