motor question?
Old 07-23-2009, 01:18 AM
98camZ's Avatar
Default motor question?
The heads have been upgraded from Patriot Performance which includes Patriot Extreme Dual springs good to a .650 lift, Titanium retainers, Super 7 Machined locks, 16 .505" ID machined spring bases, and 16 viton rubber seals. Also fitted with Patriot stainless steel intake and exhaust valves, Patriot 7.400 hardened pushrods, JP Performance Billet timing gear set, TSP ported LS6 oil Pump, and Futural Motorsports F14 FCustom Grind Camshaft - 232"/234" .646"/.612" 112LSA.
Does any body have a guess what this motor will put down behind a m6 stage 3 clutch?
Old 07-23-2009, 03:08 AM
00MaroonZ28's Avatar
You might want to see if you can find some bigger lift springs. You'll be replacing the intake springs every 10k miles.
