My 370 build-thoughts, opinions??
Old 07-23-2009, 07:44 AM
blue by you's Avatar
Default My 370 build-thoughts, opinions??
I'm planning on building a 370 when I get home next spring from Iraq and I thought I would run it by you guys and get any thoughts or ideas or recommendations. 6.0 .030" over, Wiseco -3.2cc K398X3 flattops-L92 compatible, .041 Cometics, Callies Compstar 6.125 rods, stock crank, L92 heads with LS3 hollow intake valves, 11:1 SCR, Patriot Gold Doubles, L76 intake with Holley 90mm TB, Pat G cam all in front of a T56 with stock 3.42's for now. I'm shooting for 475+rwhp. What do you guys think? Is it possible with these things??
Old 07-23-2009, 09:30 PM
tatasta's Avatar
Sounds like a good setup. Not sure about power but I think you should be close. Take care of yourself over there and thanks for all you do!!
Old 07-25-2009, 12:10 AM
Thanks! I'm just trying to get any thoughts before I drop some of the coin that I've been saving while I'm over here. Anybody else??
Old 07-25-2009, 11:42 PM
OUTLAWZ RACING's Avatar
look solid to me maby a fast 92? say good by to the pacesetters in favor of som arh 1/78 headers and i would look at some trick flows or tsp heads.
Old 07-26-2009, 12:47 AM
garygnu65's Avatar
L92 heads make power more easy than ls1 heads . i would like to go with a ls2/3 to benefit from the L92 heads.
Old 07-26-2009, 07:56 AM
I bought the L92 heads along with all the valves over a year ago, so there is no sense in trying to sell them and spend even more on AFR's or TFS's. I also already have the L76 w/90mmTB, so all I really need is the rotating assembly. I'm still debating on going with a 408, but can't justify the extra $800-1000 for the crank when the 370's I've read about are almost up there in power with the strokers. Then I can save the $1000 towards a 12 bolt that I'm sure I will need next.
Old 07-28-2009, 08:35 AM
Anybody else have a 370 with L92 heads out there with track times and/or dyno numbers or suggestions?
Old 08-04-2009, 08:01 AM
I can't believe no one else has any ideas or suggestions out there?? I know there's more than a few people out there that have built 370's......
Old 08-04-2009, 08:42 AM
sroach20's Avatar
dont just look at peak hp on engines. look at the power curve on a stroker compared to a stock stroke engine.
Old 08-04-2009, 08:52 AM
I understand that, but am going through a divorce now and don't really have the extra $1000 or so to stick in a stroker. Guess we'll how bad she tries to stick me in court. Thanks for the advice though.
Old 08-04-2009, 11:58 AM
bowman2005's Avatar
I think you can achieve the 475rwhp with that setup.you are using really good parts,but I dont know about those pacesetters. If you do go 402 you should be close.I got that type of power with a stock bottom and trick flow heads,nice size cam and a fast 92/92,but I also have all bolt ons.So I think you can do it or get damn close to it.I would'nt even try to compare a 370 to a stroker motor at all like the other guy said.Like everbody says horsepower sells cars torque wins races.Torque is exactly what those strokers have.
Old 09-14-2009, 08:28 PM
chknhwk01's Avatar
Talking Y; not
BIG BORE; SHORT STOKE ..
FASTER THAT THE LONG STOKE.. WHAT YOU GOT IS A FASTER REV....
MOTOR MAKE LOTS OF POWER...YOU GOT THE FASTER MOTOR..
HIGH 11 N/A....
Old 09-14-2009, 08:37 PM
chknhwk01's Avatar
Talking Y; not
HIGH 11 N/A..
Old 09-15-2009, 04:58 AM
99blancoSS's Avatar
HIGH 11 N/A..
Yea thats why GM went to a 4" stroke on the LS7 427 right??
What you have is 370 cubic inches and it's not magical.
Old 09-15-2009, 09:15 AM
jmm98LS1's Avatar
I put down 495rwhp/445rwtq through a 3" steel drive shaft and moser 9" with my lil 370ci, your goal is certainly attainable. It pushes my 3900lb tank of a car down the track at 120mph in 2700ft DA......with a good driver it'd be low low 11's, with me driving I get pretty consistent mid 11's.
Old 09-17-2009, 12:34 PM
Thanks for all your input guys! I finally coughed up the extra cash for the crank and went with a 408. Compstar crank and rods along with Wiseco pistons. Should get me about 11.4 to 1 CR.
Quick Reply: My 370 build-thoughts, opinions??
