my camaro won't start
Old 07-23-2009, 09:25 AM
MOZART9T's Avatar
Default my camaro won't start
hi
I'm having a problem with my 2002 camaro
my problem is that I have to turn the key for 1-2 min untill it start
this happen most of the time and I just have to wait until it turn on
I changed the ignition switch, check the battery but the problem isn't going
what do you think it might be the problem
Old 07-23-2009, 11:15 AM
fleetmgr's Avatar
Have you checked your fuel pressure? Have you changed your fuel filter recently?
Old 07-23-2009, 11:22 AM
Dewey's Avatar
more info please, will it just turn over for a minute and then start, or does it not make contact and do nothing? does the starter sound strained? details, chief... details. where do you live by the way.
Old 07-23-2009, 11:23 AM
Ice78Transam's Avatar
sounds like a fuel problem if it starts...after a while. But much more detail please.
Old 07-23-2009, 02:12 PM
MOZART9T's Avatar
while the key is turn on ,it does nothing for 1-2 min then start suddenlly
nothing happen when I turn the key on, only the gages turn off, which mean there is a contact
I didn't check fuel pressure nor changed fuel filter
I'll have to check it tomorrow
sorry but I'm not so good in English , I'm from Saudi Arabia
Old 07-23-2009, 02:47 PM
fleetmgr's Avatar
No problem, we'll get it worked out.
When you say with the key on, it won't start for 1-2 minutes. Is this with the engine cranking, or only the key on?
Old 07-23-2009, 03:41 PM
99monguse's Avatar
Did you try the ignition relay by chance? Try swapping one of the fan relays into the ignition relay.
Old 07-23-2009, 11:50 PM
Dewey's Avatar
i think i know what is happening. try this, it may be as simple as the starter fuse in the cabin fuse box is bad. just take out the fuse labeled something like stater 2 or ignition. take that fuse out altogether and turn the key. if that works then you need to replace the ignition relay. it'll either be a ten amp or a three amp fuse.
this happened to me at work one night. the truck would kill the gauges and stereo, then do nothing as if it were turning over. all i did was pull out the ignition fuses, and the truck just started. you will hear some strange noises, all you have to do is put the fuses back in to make the beeps stop.
Old 07-27-2009, 07:02 AM
MOZART9T's Avatar
the engine won't crank, the lights in the panel will just go off and I have to hold the key in the "on" position for couple of minutes until it crank and start
I tried removing the starter fuse and tried to turn it on but nothing happened, and the lights didn't even go off
Old 07-27-2009, 07:10 AM
MOZART9T's Avatar
I replaced the relay with a new one and that didn't work either
Old 07-27-2009, 12:17 PM
robinpugs06's Avatar
fuel pressure regulator?
Old 07-27-2009, 12:50 PM
LS6427's Avatar
1-2 minutes....damn thats a long time to crank that starter. You're gonna be buying a new starter if you keep doing that.
Did this start "all of a sudden"...or has it been slowly building up to this over time.
Old 07-28-2009, 03:12 AM
MOZART9T's Avatar
Note: the engine will not crank for whole time "1-2 min.", I just hold the key at the "on position" and nothing happens for "1-2 min.", and after that the engine starts to crank and it would start right away
I hope I made it clear this time
Old 07-28-2009, 09:27 AM
Dewey's Avatar
Yes. That is much clearer, thank you. It sounds to me like the lock cylinder in the ignition mechanism is not making contact. When you replaced the atarter switch, what was replaced? What I mean is did you replace only the starter switch or the lock and ignition cylinders at the same time? When you get a chance try this: either try to turn the key very slowly in the ignition or try to move the key around in the cylinder if that doesn't work.
Old 07-29-2009, 10:12 AM
MOZART9T's Avatar
This is the part I changed the last time,
and this is a clip for the problem I took today
http://www.youtube.com/watch?v=dJcuBm0UFMk
Old 07-31-2009, 04:25 AM
MOZART9T's Avatar
up .....
Old 08-01-2009, 01:14 AM
Dewey's Avatar
after watching the video several times... i'm stumped. i've never seen a car do that before. the only suggestion that i can make is to get a new key cut from the VIN number of your car (or the key code engraved onto the ignition cylinder in the picture above) - an oem rounded key, not like the one you have now.
Old 08-01-2009, 01:25 AM
LS6427's Avatar
That would make for a shitty get-a-way car.
Get yourself a new key, the resistor in the key could be wacked.
Old 08-25-2009, 01:44 PM
rabbit320's Avatar
any new news from this? i think i am having same problem...
Old 08-26-2009, 10:37 AM
Norway's Avatar
im having the same problem too, it occurs completely at random for me
Quick Reply: my camaro won't start
