Any Houston Mechanics looking for side work?
I live in Pasadena (SE side) but i can drive to wherever in Houston
i failed inspection...and i have a ticket for it so i need to fix what's wrong as just clearing the codes didn't get me by as they keep popping up
my engine sensor 20 fuse keeps blowing cuz of the solenoid issue with reverse as in i have to push hard to put it in reverse, but if i replace the fuse it works fine
not sure if the cags wire or whatever down there got damaged
awhile back i swapped my stock gas cap for a locking gas cap well, driving home i was high like a **** cuz the aftermarket locking gas cap was leaking vapors or something so i put the stock one back on there
now it keeps tripping a service light, and i have no idea why
it must be a vacuum issue on the cap or the line
i had the codes written down but i can just write em down when i see em up again
pm or reply and i'll drop u my fancy digits
oh if you're wondering why i tried to pass inspection with a badsetup
i honestly figured i could just clear the codes (plugged in a new fuse so reverse/eng sensor fuse) was fine
and pass it, didn't realize it was no diff then unplugging a battery
(as in u need 50 miles clocked afterwords which obviously would trip a fuse again)
