express down relay?
Yep but you'll need to paypal me 5 bucks to tell you
nahh just joking.....lay down on the drivers side floor and pull the covers off ubder the dash. Reach your hand up over the throttle pedal to the firewall at the trans hump and you will feel-see a square box molded into the plastic floor liner. In that molded box is the exoress window module. I disable it by bending tab C out of the way of the connector so the express feature no longer works. I think its the dunbest feature gm ever came up with.
If they would have done it so you could hit the switch twice and it would express down then it would be a great feature..BUT ITS NOT!
I see you have another thread started about this....your trouble is there is too resistance someplace inthe window assembly and the circuit breaker for the window motors is kicking out. Your new motor may be bad..
