About to step up to bigger nitrous system, need advice.
I currently have an all forged HKE 347 bottom end with 9.2:1 compression built for a turbo setup that will hold over 1000 rwhp. I want to be able to keep my spray when I get the boost going as well. I am currently running a 150 dry shot (175 being the threshold for my current fuel/MAF setup). Until I can fully afford the turbo setup I want, I figured I could go ahead and up the spray to have some more fun in the mean time.
First off, I am probably definately going to go ahead and get a dedicated fuel system so that that won't even be an issue. I have heard that big nitrous setups are really better suites for higher compression and that piston gap of
my dished pistons might be a bad thing under heavy spray, is that really the case? I think I could get away with a 200 shot no problem but would a 250 be pushing it?
The next big question is should I step it up and go with a plate kit or simply a dual nozzile setup on the bellow? I have read mostly that the plate is the way to go but someone also told me that they have a tendency to burn up plugs. Also, is it really worth it for me since I will probably just move down to something like a 75 shot once the turbo is on? Most people say Harris Seed Works makes the beat plate but Nitrous Outlet told
me that their's was good for over a 300 shot.
Who ever tolds you a plate burns up plugs needs to figure out how to tune a nitrous motor because that is simply not the case. It is something called operator air and not understanding how to tune.
I would run a plate over a dual nozzle for simplicity, function, and it just makes it look better. Im pretty sure hsws plate can go that high but not too sure. As for the motor and holding up im not to sure so I wont help to answer that.
As for how much you can spray, Id call up eric and HKE and see what he recommends based on piston choice and ring gap. I doubt you'll have a problem going to 250.
As far as i know our Brute Force plate is the highest flowing plate on the market and you could spray that much. I dont recommend it though, when getting to 225-250+ i do suggest a direct port. A dry direct port with our interface controller would actually work really well with your setup. A wet system would work equally as well but costs a bit more. Since you'll eventually be running a small shot i think the dry would work great. Also, and i consider this the most important thing. You would be wasting your time getting a dedicated to eventually go turbo. I would suggest upgrading your current fuel system as if you are putting on the turbo now. This way it will support a dry system and fill your needs once you go turbo.
This is the same question I have. I build my motor to put a Procharger in it.
4.00” STROKE
3.905” BORE
9.1:1 COMPRESSION
383 CU IN3
• Stage 2 heads
• 220 Comp Cam
• Clevitte cam, main & rod bearings
• Eagle 4340 4.00” stroke crankshaft
• ATI damper
• Eagle 6.125” connecting rods
• Diamond pistons & ring set
• Ferrea intake & exhaust valves
• Valve guides
• GM timing chain set
• ARP head studs
• Cometics head gaskets
• Fel Pro performance gaskets
• Melling oil pump
• Chassis dyno & tune
• FAST 60#/hr fuel injectors
4.00” STROKE
3.905” BORE
9.1:1 COMPRESSION
383 CU IN3
• Stage 2 heads
• 220 Comp Cam
• ATI damper
• Valve guides
• ARP head studs
• Melling oil pump
