i'm stuck!! new to the chevy world
i have a 91 corvette with a 5.7 ltr. i am getting fuel to the rails, i have spark, but i have no injector pulse. i replaced the pcm, and the ignition module. still have no pulse, i checked all of the fuses. if i spray starting fluid in the manifold, the car will start and run for 30 seconds. do you guys have any suggestions???????
Sounds like an vacuum leak at the manifold. Whether between the throttle body and manifold or Manifold & engine. Check & make sure that the fuel rails are seated properly first and then go on. I had an issue when I installed an LS6 intake on an LS1 engine similar that turned out to be the gaskets on the LS6 intake.
http://www.2carpros.com/first_things...wont_start.htm
Maybe this will help.It could be a lot of things...would have to be there to troubleshoot the problem.It could be anything from a Crank Position Sensor to a Throttle Position Sensor on your throttle body stuck in the WOT position during start up and causing the ECM to go into "clear flood" mode.
