fluid leaking
Old 07-25-2009, 08:54 AM
PONTIAC SLP's Avatar
Default fluid leaking
hi guys , when i was at my buddy's home yesterday he told me there are fluid leaking under the rear end cover then I saw under the car and there are fluid leaking under the rear end cover . what do u think guys ?
Old 07-25-2009, 09:24 AM
SparkyJJO's Avatar
Check the bolts to make sure they are still tight.
May just need to take it off, clean off old gasket material, and put a new gasket on.
Not to sound like a jerk, but if it is leaking then either something is loose or a seal is bad.
Old 07-25-2009, 03:12 PM
Lambert695's Avatar
ha sounds like you have a leak.
you kind of answered your own question really. I agree, check seal.
Old 07-25-2009, 05:31 PM
hey guys , i have this cover installed from TR can i open the cover and fix it by myself ?
Old 07-25-2009, 06:18 PM
Lambert695's Avatar
yes, just buy that gasket to replace the old one when you take it off.
Old 08-02-2009, 03:52 PM
thanks problem fixed , i replaced the Gasket.
