Best inexpensive Heads & Cam package??
Old 07-25-2009, 11:58 AM
sspower23's Avatar
Default Best inexpensive Heads & Cam package??
Hi guys,
I know everyone on here has had this question asked before. Ive spoken to alot of companies, shops, that make heads & cams and they all seem to be good.
I just wanna know from you guys, the purchasers, whats the best "PROVEN" heads & cam setup to give the most Torque and horsepower for an "LS1" ?? Where do I buy from and how much did YOU pay??
Im gettig the Dana 60 rearend and driveshaft, clutch, etc. But now its cam & headers time.
Thanks guys
Old 07-25-2009, 12:02 PM
fccs's Avatar
Either get whatever heads you have ported or pickup some 243 ls6 heads.
Old 07-25-2009, 12:04 PM
RARON455's Avatar
As far as price and performance I dont think you will beat Texas speed and performance, they are a sponsor on this site and they can get you into great set of heads, I have the PRC stage 2.5 5.3 heads for about 1200 bucks, and that is a price that is fantastic. Talk to them and they will spec you out a custom cam if you dont want an off the shelf one. Super guys and I will recommend them to anyone.
There are a ton of guys on this site with TSP head and cam combos posting super numbers and track times. Hope this helps. If money was no object I would say the trick flow heads, but they are more than twice the tsp heads.
Old 07-25-2009, 12:05 PM
homerunhtr21's Avatar
How much power do you want? Daily Driver? Track Car? M6? A4? Way to many questions to answer. But Texas-Speed has just about the best deal on a head/cam setup. Prc 2.5 5.3 and a 224r cam. Stage 2 ls6 heads 228r....Tv2, Tv3, ms3, ms4 ...so many options to choose from.
Old 07-25-2009, 07:50 PM
sspower23's Avatar
Well I have an 01 camaro ss, LS1 stock, 6 speed, daily driver and track. I want the most power possible from this block. Trickflow sounds like the best however, PRC sounds reasonable.
Anymore suggestions please
Old 07-25-2009, 07:59 PM
Johns00Z28's Avatar
You can't mention inexpensive heads and TFS in the same sentence...lol
Old 07-25-2009, 08:44 PM
lookin4aTA's Avatar
That is s very true statement lol
Old 07-25-2009, 11:17 PM
Black 99 Bird's Avatar
Again not cheap but take a look @ LG motorsports.
Old 07-26-2009, 09:27 AM
vettett15's Avatar
Here is my setup:
TSP stage 1 ls6 heads milled to 59cc (ended up costing me ~$800)
LS6 intake (~$300)
Bosch injectors (~38's?) ($100)
MTI G1 cam (228/232 high 500's lift) (came with the car, don't think it is made anymore, but I'm sure there are better cams out there).
Tuned by Mike Norris.
439/411 (Yes I know it is in STD but Mike's dyno supposedly reads low.
File Type: pdf
Old 07-26-2009, 09:53 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We're finishing up another new camshaft that's under 230 duration that combined with a PRC Stage 2.5 LS6 or 2.5 5.3l should do very well. Either of those combos are well under $2000 with cam & pushrods!!
http://www.texas-speed.com/shop/item...d=203&catid=47
http://www.texas-speed.com/shop/item...d=832&catid=47
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 07-28-2009, 12:03 PM
sspower23's Avatar
Jason from Texas speed, hey I want to buy your PRC stg 2.5 LS6 cnc ported heads. However, I want you to find or custom grind Me the "Torquiest" Cam for these heads. These heads have a lift of up to .660 lift so I want a cam that can lift to at least .650. Let Me know ok, then I buy. Remember Torque, low to high power band pls, thanks
Old 07-28-2009, 02:10 PM
Mumbles's Avatar
This is a bit off topic, but why the Hell are the Trick Flow packages so damned expensive? Forgive me for the hijack O.P.
Old 07-28-2009, 03:25 PM
OUTLAWZ RACING's Avatar
I think because trickflow makes there own casting vs teaxs speed that takes gm head and turn it into a master pice. Its about how much work goes into the head. I think imho texas speed has a dam good program for their heads and cams. Im not a **** rider I have never purchase anything from them. But I always see their head and cam combos putting down 400+ on 346.
Old 07-28-2009, 03:30 PM
streetassasin's Avatar
best? I'd say the prc 2.5 5.3 ms3 combo. I had it but had to sell it to pay some bills
Old 07-28-2009, 10:00 PM
Mumbles's Avatar
Makes sense. Thanks.
Old 07-29-2009, 01:21 AM
HitmanLS1's Avatar
I guess texas-speed is the way to go. I seen some trickflow heads for 1700.00 per set. What about patriot heads are they any good? DART & AFR'S are they a good head also?
Old 07-29-2009, 02:42 AM
jmill96Z's Avatar
TEA
Then have Patrick G spec out a cam
Old 07-29-2009, 04:58 AM
zacht's Avatar
does tsp give you credit if you send them 243's?
vettett15-sounds like a pretty sweet combo, ive been looking into the stage 1 243's as well. how did you get them for 800?
Old 07-29-2009, 07:19 AM
DCsLS1's Avatar
check out patriot heads too they are usually around 1200 witch is pretty good. i got my heads for 1285 fully assembled (springs, valves). AFR's are very expensive and i dont see why they would be any better then a package from tsp or patriot heads especialy when you can get heads, cam, and push rods from TSP for less then just heads from AFR or trick flows. But remember to pick your heads for what you want down the road for example you dont want 5.3 heads if your are going to go FI eventually or you wouldnt want to get 72cc combustion chambers in your heads and lower your compression if you want an NA engine there is lots of choices for heads and cam out there just do your research before you buy one and youll be happy with what you get.
Old 07-29-2009, 07:25 AM
Internet Mechanic
BlackScreaminMachine's Avatar
When i comes to a lot of things, you get what you pay for.
There are some great cams that can often do 380-400 rwhp alone.
I am torn on the cyl head issue as the head I would put on is a TFS but with the cost and requirement of roller rockers on a smaller bore motor like the stock 346 and IF/WHEN I blow it and go up to a 4.000+ (or more cyl bore) then the heads may not be optimal and the cyl head choice opens up dramatically. I am honestly expecting never to put a improved cyl on the motor unless I fucked one up and I didnt have the $$$ for a new bullet.
Quick Reply: Best inexpensive Heads & Cam package??
