Help!!! Misfire
Help!!! Misfire
I have a 98 camaro , I was driving it home car was running fine doing about 60. Got off on to a main road and slowed down to about 35 and the car started missing and pulled the ses light then it started flashing. I got it home and run the codes po 307 #7 misfire, po351 coil 1 malfunction, and a po353 #3 coil malfunction . Changed all plugs and put in new ngk tr55, and two new coils, now still got the #7 misfire. Any suggestions?
new plugs and msd wires. both ends snapped on good. i have had them come lose before so i check them often
just found out that i broke some valvesprings!(again???). i just can not figure out why this keeps happening? some friend who work on cars said someone has put a bigger cam in it and did not change the valve springs. could this be the cause????
when i started pulling it apart we found that it has lunati push rods in it and noticed that it has new gaskets on the timing chain,heads and intake.just wish i could find out what springs i need to stop this.
