removing turn signal lights ??? HOW????
how in the hech are you supposed to remove the turn signal lights in a TA. I would like to sand them down and polish them up bc they are looking pretty crapy and pitted. Im not talking about the side markers nor the fog lamps. thanks in advance
what year? even though i dont think the process differs very much year to year. for something quick like changing the bulb you pop the lights up, un screw the black casing around the light and you can reach down and pull them out. i guess you could manually put the lights up to save your battery but i just flick the switch. Or get under the car, take off the plastic splash guard (what ever its actual name is) and take it out that way, not alot of working space and if you want to take the actual lens out like i did i jacked the front end up to get to it.
