will not idle after cam install
just finished my cam install and we cant get it to idle, off idle runs like a champ.
the engine was totally rebuild so trailing it to get it dyno tuned is not an option because i need to break the motor in.
the cam is a tr230/224 w/40bph injectors
we do have hp turner so we can play w/the tune.
any ideas?
any ideas?
well we got a tune from hp tunes website, for a heads cam car w/38bph injector, but it still was not right. it would not idle and it was running very rich.
Moderator
Mine had a lot of trouble starting / idling after the
cam went in, mostly the low end of the VE table
needed cleaned up. It was way overfueled until I
got that part straight. The cold EQ vs ECT and
afterstart enrichment were also way more than it
wanted. Gas, gas, gas.
Reset your idle. We just did the same cam in my car, but with a 7.25" clultch and button flywheel (-30lbs from stock). It would idle, then surge itself into a stall. The tuner went in and upped the idle RPM to about 1000 or so. It got rid of the surging.
Of course, this was just a fix until we got it on the dyno and could fine-tune things. But, it let me drive from Point A to Point B, and move the car around.
