View Poll Results: Which intake for a serious street car
Fast 92/92
10
24.39%
Vic Jr. w/ elbow and TB
13
31.71%
Vic Jr. w/ 4 barrel TB
16
39.02%
Other options please list.
2
4.88%
Voters: 41. You may not vote on this poll
Victor Jr. on a street car?
Old 07-26-2009, 12:09 AM
MelScrilla's Avatar
Default Victor Jr. on a street car?
I'm in the process of planning a build right now as you can see in my sig i'm in the process of acquiring all the bolt ons. In the future i would like to do an intake heads and a big cam.
I have a couple of questions about intakes.
Will a vic jr. work on the street or do you lose the all low end power?
What kind of tune is needed for a 4 barrel throttle body?
should i just stick with an LS6 or a fast?
Old 07-26-2009, 12:20 AM
tripblackls1's Avatar
well whatever you do, do not use vic jr w/elbow, with that said all the others are good choices but if you do 4 barrel tb then your going to have to cut some of the cowl and there is not a good looking way to put an air cleaner on it
and well the fast is just to damn expensive
also if you don't mind cutting the cowl and removing your wipers check out the pro flo xt
Old 07-26-2009, 12:43 AM
MelScrilla's Avatar
does the elbow kill power? it seems like alot of the race guys use it.
and would it be possible to fab a tube like the intercooler piping on a turbo to run from a 4 barrel to a lid maybe w/ MAF?
Old 07-26-2009, 12:44 AM
MelScrilla's Avatar
oh yeah i think i would like to keep the wipers because the car will see some street duty.
Old 07-26-2009, 06:57 AM
sparkwirez06's Avatar
click pic to enlarge http://www.turbols6.com/gallery/TYPHOON-LSX-TURBO/avb
Old 07-26-2009, 07:50 AM
blownws6_nc's Avatar
I say the fast. I had a victor jr. on my procharged car and did'nt like it at all. I went back to a fast, and the car felt alot better down low. also the fast fits better. i did'nt like the way the victor jr. with the elbow fit at all, as some of the rest will tell you, you have to modify you cowl to make it work. imo. it would be ok for a track car, but not my car, as I am far to curious to ride around with it.
Old 07-26-2009, 08:36 AM
MelScrilla's Avatar
thanks for the input
so far fast for the win
Old 07-26-2009, 12:16 PM
stumprrp's Avatar
how can a procharged car feel shitty down low with all that torque? lol
unless its a 13:1 comp with a 260 cam i think you will be fine with a fast intake, they are expensive but seem to have the best results.
Old 07-26-2009, 12:25 PM
If your talking to me, you need to reread my post. I like the fast over the victor jr. I never said it felt crappy, I just stated the fast picked up the bottom end more and imo. it is the better street intake.
Old 07-26-2009, 12:38 PM
StreetSilverado's Avatar
I know of two buddies with a Victor JR. and 4barrel set-up. The one I rode/drove was a 408 stroker with the victor jr and man that thing was litterally a beast all around. Never got it to run right because of trans/converter problems but with it having 1st gear and part of second it pulled a 1.50x 60ft and ran a 7.2x at 72.xxmph in the 1/8th. I'll be going with the victor jr/4 barrel set-up with my 370 .
Old 07-26-2009, 12:41 PM
the 4 barrel setup work alot better than the elbow setup I had.
Old 07-26-2009, 12:44 PM
Old 07-26-2009, 12:50 PM
silverbeast's Avatar
when you run an elbow set up with the victor jr it kills the bottom end. The 4 bl set up is the only way to go if you are going to run that intake, IMO. But for a street car you cant beat a ported fast, period.
Old 07-26-2009, 12:52 PM
And Blown ws6 is right, his car ran ALOT better with the fast intake over the Victor Jr.
Old 07-26-2009, 01:02 PM
danhr's Avatar
who says you can't run a 4 barrel throttle body on a street car?
you run a carb style hat that they use for carb. turbo/supercharged cars, and use that as an elbow and run that either to a filter or your lid.
come race time, take the wing nut off the hat, and just lift everything off, and instant race car!
The following users liked this post:
nickslt1 (09-27-2019)
Old 07-26-2009, 01:12 PM
+1, just look at the picture I posted up
Old 07-26-2009, 01:26 PM
Originally Posted by StreetSilverado
this is very nice, but does it kill bit of power?
also how much did that cost? i think last time i looked into it the hat alone is like 100 bucks right?
Old 07-26-2009, 01:33 PM
$91 from spectre, no there's no power loss with the right set-up
Old 07-26-2009, 01:37 PM
danhr's Avatar
I'm at work and can't see the picture....
but I will post this up, if it isn't the same thing...
And that's with a Victor jr... you can still run a shorter GMPP single plane
Old 07-26-2009, 01:46 PM
It's the samething, it's one of the buddies I was talking about with the set-up
My picture has the Accufab 4 barrel and the one you posted has the edelbrock 4barrel, pretty much just a height difference between the two.
Quick Reply: Victor Jr. on a street car?
