Manual Transmission - Clutch problems, rear end????
View Full Version : Clutch problems, rear end????
luisdm
07-26-2009, 07:49 PM
ok from a stop when i let go of the clutch it starts chattering, then it takes a while to stop slipping and finally grab to move the car into 1 gear speed. also on higher gears if i try to speed up the clutch will instantly slip. this means i need a new clutch right? cause i already bought one
also what [rear end-drive shaft] do you guys reccomend for 700-750hp?
thanks
Gen414
07-27-2009, 08:48 AM
thanks
Yes, sounds like clutch problems.
For 700+ HP, go 12 Bolt, 9", or Dana 60 (rear end) any number of aluminum driveshafts available for the FBody, and a Monster Level 3 or 4 Clutch (depending on what you are wanting to do). You can check out prices in my link below for teh Monster Clutch(sale runs until the end of this month) and you can call me as well, and would be happy to assist you.
