Is oil plug sludge normal? (PIC Inside)!
Old 07-26-2009, 09:48 PM
dub.ya.es.SICK's Avatar
Default Is oil plug sludge normal? (PIC Inside)!
I have had this car for 35,000miles and this is on it every time no big chips or anything but this is always on it!!! Anyone else?
Attached Thumbnails Is oil plug sludge normal? (PIC Inside)!-20090726151842.jpg
Old 07-26-2009, 09:54 PM
Formerly darynC-10/23/10
Daryn's Avatar
what kind of oil you use?
Old 07-26-2009, 09:55 PM
LS1Formulation's Avatar
Yep, pretty much every oil change. It's relatively common, as there's always tiny metal shavings coming off the valvetrain, the rods and the crank. Nothing to be worried about.
Old 07-26-2009, 10:11 PM
conan's Avatar
Same here, you'll get wear on the magnent every time.
Old 07-26-2009, 10:21 PM
David_viny's Avatar
Ewww, I don't get that when I change the oil...
Old 07-26-2009, 10:25 PM
NBM-LS1's Avatar
Probably because your drain plug isnt magnetic?
Old 07-27-2009, 08:06 AM
i always use mobil 1 synthetic or castrol synthetic.....0w40 or 5w30
Old 07-27-2009, 11:45 AM
onebadZ28's Avatar
i get this every time i change my oil also, and i use mobil 1 synthetic i just passed it off as being normal wear from the rotating assembly, valvetrain.
Old 07-27-2009, 01:59 PM
Alright then that is reassuring....
Old 07-27-2009, 02:20 PM
conan's Avatar
Mobil 1 here too. My oil gets changed every 1,000 - 1,500 miles just because I dont drive it much (3 month rule). When I do drive it, it get driven hard and I get that wear on the plug. I have seen the same amount of wear on my magnet with the original engine and my forged moter.
Old 07-27-2009, 02:40 PM
c0ncEpT's Avatar
100% normal.
Old 07-27-2009, 04:12 PM
Sounds good to me!
Old 07-27-2009, 05:42 PM
joecar's Avatar
Mine looks similar every 5000 miles for 110K miles... I use M1 0W40.
Old 07-27-2009, 06:12 PM
aalllllriiiighhhhttt1
Quick Reply: Is oil plug sludge normal? (PIC Inside)!
