Gears & Axles - Gear brand poll!!!
View Full Version : Gear brand poll!!!
IKnowtheFuture
07-27-2009, 12:12 AM
whats the best as far as power handling, quietness, and reliability? :corn:
SyckWS6
07-27-2009, 12:37 AM
Richmond had a reputation for quality and durability, however they aren't known to be quiet by anymeans. Motive are moderately priced and are relatively quiet (or atleast the ones i owned in the past were). SLP ring and pinion sets have kept me very happy as far as durability and sound is concerned. They are a bit more expensive than the other two i have mentioned, but for now, they will be the brand i stick with.
7.0 camaro
07-27-2009, 06:14 AM
i think gm makes the best gear. ive got pics of a 4.10 richmond gear sitting next to a 4.10 gm gear and the gm gear is bigger with more meat on it. and they are 3 cut gears while most aft. are 2 cut gears. that helps them be quiet.
RARON455
07-27-2009, 08:10 AM
Yup, definately should have put OE gearsets in the poll, when I buy I would rather have a nice set of used factory gears than aftermarket ones.
7.0 camaro
07-27-2009, 08:22 PM
the older s-10's that had a 2.5 and 5 speed had 4.10's stock. the stock gear is on the left. the busted up richmond is on the right.
2000Z28M6
07-27-2009, 09:03 PM
I have a set of GM 3.73s on mine and no complaints.
They tend to drone a little around 60-70mph, depending what rpm I'm in..but honestly I think even the 3.42s were about the same. I think the rears tend to whine a little stock or not.
I had a little mishap when I first had them installed (fucking curb) and the pinion bearing got trashed, it whined loud! Had the bearing replaced and it's been great!
They've been in for over 2 years and holding up nicely.
jetlag
07-27-2009, 09:10 PM
Does Moser have their own gears or do they use another company?
SHovV
07-27-2009, 11:46 PM
looks like OEM FTW.
jimbo98z
07-28-2009, 12:58 AM
Moser makes their own gears. And mine sucked from them. Put a set of Yukons in the 12-bolt and they seem to be pretty solid. A little noisy, but that's due to how it's set up, not the gears themselves.
kmgsix08
07-28-2009, 10:22 AM
i vote GM. i waited to find a set of GM 4.10's before doing the rear end rebuild
sroach20
07-28-2009, 10:33 AM
aam are good ones.
kmgsix08
07-29-2009, 10:12 AM
aam are good ones.
i was just informed that AAM makes the gears for GM
7.0 camaro
07-29-2009, 10:39 AM
nice to know. i wonder whats the price difference on a new gear. i usually get them from pull a part.
01ssreda4
07-30-2009, 12:06 PM
i just installed summit 4.10s in an auto car and :barf:. Maybe summit (noisy fuckers) are made by richmond?
7.0 camaro
07-30-2009, 01:27 PM
very possible. not sure exactly though
C_B64
07-30-2009, 10:43 PM
I like Motive, but the last gear I got was a Yukon Gear and its pretty quite and seems to be fine......
98silvertacrbn
07-30-2009, 10:52 PM
I had the same set of gears from summit and they were noisy as fuck also!!
But i have installed several sets of motive and oem ford gears and they have all been quoit
