6.0 swap????'s
6.0 swap????'s
what all do i haft to do to swap a 6.0 into a f-body? Is there something to do about the alternator holes. I am using f-body brackets. The motor is a 05, out of a truck.
thanks
thanks
You can find much info in the Conversion/Hybrids section on swapping a iron 6.0L into place. but as you have already been told.. the front PS/Alternator bracket will not be threaded in the block boss, but it can be tapped. Some have tapped it and other have just not did anything.
