blow thru 454 turbo suggestions
Old 07-27-2009, 04:38 PM
89importeater's Avatar
Default blow thru 454 turbo suggestions
thinking about putting twin turbos on the 454 mark IV in an 89 camaro. some suggested 2 60-75 mm with a a/r less than 1.0. it will be on a street/strip car so i would like some grunt down low but also want it to move out pretty good on down the track. does the suggestions on turbos sound about right? also i notice they are 100's of turbo listed on ebay that fit this bill but could you give me a actual turbo to look out for, like name and stuff. i was also told possibly a s400 may fit the build for a single setup but was thrown the idea that twins may be easier to fit in the car the a larger single. what are some of you guys thoughts. a good, "cheaper" turbo is perferred but all suggestions will be considered.
Quick Reply: blow thru 454 turbo suggestions
