Conversions & Hybrids - plastic truck fan
UNmolestedTA
07-27-2009, 09:11 PM
How do I remove the plastic truck fan on the front of my engine? I know this is a dumb newb question but I need to know. Thanks
chevellepowered
07-27-2009, 09:22 PM
you get a big ass wrench, and un screw it..
its a pain in the ass.. i use a vise grip plier to hold waterpump, then un screwed it.. i didnt care if i broke it.. but it didnt,,
UNmolestedTA
07-27-2009, 09:31 PM
Thanks
knievel
07-27-2009, 09:35 PM
They make a spanner wrench to hold the wp pulley and it unscrews
Shon Herron
07-29-2009, 03:22 PM
I got a huge crescent wrench, tapped it pretty hard while on the nut and it will come right off, not as difficult as one thinks!
NemeSS
07-29-2009, 03:26 PM
i use a flat end steel rod and a hammer, give one good hit to the edge of the bolt and it breaks loose. or a reaaly big set of vise grips, if its on there too tight the big crescent wrench can round off the edges of bolt. if not done correctly
Shon Herron
07-29-2009, 03:27 PM
Center it just right!!
ls1astre
08-01-2009, 11:18 AM
i use a air hammer on the edge of the flat. must be centered. just light the guy who said use a rod and hammer. that will work too.
UNmolestedTA
08-01-2009, 08:11 PM
pipe wrench and a huge crescent wrench. BTW do I need to put a nut on the end of the water pulley?
cutlass_455
08-01-2009, 10:20 PM
I used a vise grip that has a chain that goes from jaw to jaw around the pulley and a big cresent on the fan. No hitting required. Just dont muck up the pulley.
04600rr
08-01-2009, 10:46 PM
I second the air hammer....this is the only way I have done it
frojoe
08-03-2009, 03:30 PM
Any word on this? Is the pulley press-fit onto the waterpump?
Scoggin Dickey
08-03-2009, 03:39 PM
The pulley will stay on, it's not held on by the fan
Shon Herron
08-03-2009, 03:40 PM
Any word on this? Is the pulley press-fit onto the waterpump?you will want to make sure but I think they are press fit, but there was a few that came out that were not but I still think the fan nut does not hold anything on the WP but the fan. it along for the ride.
52 Rat
08-03-2009, 05:26 PM
Is the fan nut left or right hand threads? I need to remove mine as well.
cutlass_455
08-03-2009, 08:21 PM
Its lefty loosy righty tighty.
52 Rat
08-03-2009, 09:11 PM
Thanks, wanted to make sure before putting the big hammer on it.
