underdrive pulley?
Old 07-28-2009, 12:00 AM
BIG BILL 2000 Z's Avatar
Default underdrive pulley?
alright im thinking of buying one of these two:
1. ASP underdrive pulley system for 98-02 LS1 F-body
or
2. SLP Harmonic Balancer/Underdrive Pulley, 98-02 LS1 Camaro/Firebird
which is better and what do you guys use? gains? pros and cons?
thanks,
billy
Old 07-28-2009, 12:14 AM
LS1-NAVY's Avatar
i got the slp/powerbond because of the high wall so no belt throwing
Old 07-28-2009, 12:25 AM
Dragman's Avatar
I also have powerbond no issues here either!
Old 07-28-2009, 12:34 AM
blue98Z's Avatar
I have the ASP and havent had one problem.
Old 07-28-2009, 01:00 AM
Xtreme864's Avatar
how much of a gain do these give? is it noticable at all?
Old 07-28-2009, 01:16 AM
HitmanLS1's Avatar
Which one will work the best with a double roller timing chain? I hear that some people have clearance issues.
Old 07-28-2009, 01:41 AM
Detoxx03's Avatar
I run the SLP
Old 07-28-2009, 07:05 AM
teke184's Avatar
i have the ASP for 6yrs....threw the belt one time.
gains are pretty subjective.
you'd have to be really tuned in at the track to see a gain, since the best you can hope for is about 5hp.
usually people notice the faster rev-up after the swap.
Old 07-28-2009, 10:40 AM
is it worth the 200 bucks then? i mean 5 hp is not much for that kind of money
Old 07-30-2009, 01:10 PM
worth it?
Old 07-30-2009, 01:51 PM
bigti99a's Avatar
it will help a little and it can be done in an afternoon, i say go for it. i have the powerbond unit and dont regret it one bit.
Old 07-30-2009, 01:53 PM
MonmouthCtyLS7's Avatar
If you do a search on this board I think tsp and a few others said they gained 8hp...pretty good for what it is.
Old 07-30-2009, 03:53 PM
2002 SS's Avatar
i got the powerbond, been great so far...
Old 07-30-2009, 04:02 PM
its sounds like most people have gone with the SLP powerbond instead of the ASP? why is that...
Old 07-30-2009, 08:42 PM
_JB_'s Avatar
I'm running a March, never had any problems in over a year
Old 07-30-2009, 10:03 PM
do you like the march u/d? any power increases?
Old 07-30-2009, 10:24 PM
SladeX's Avatar
I've been running the March kit since summer 07. So far no problems. For a manual car its a no brainer. The idle is higher so at idle + underdrive, accessories are running the same speed as they would in an auto while in gear.
Look at it this way, with your accessories running slower during the higher rpm runs, you put less of a beating on them.
Old 07-30-2009, 10:29 PM
i have a A4 but im sure the march u/d would still work fine
