P/V clearance with milled heads???
Old 07-28-2009, 11:15 AM
6th gear's Avatar
Default P/V clearance with milled heads???
I will be running a ASA cam with 2.02 heads that are milled .030.Should i be ok on clearance?Thank you for your input,and not ripping my head off about search like on ls1gto.
Old 07-28-2009, 11:18 AM
JPH
JPH's Avatar
What's the cam spec?
Old 07-28-2009, 11:27 AM
TooLateVTEC's Avatar
The ASA cam is like .525 lift but cant remember the duration. I would say it would be fine b/c the lift is lower than average cams these days.
EDIT:
Found the specs, 226/236 .525/.525. I would say you'd be fine. My setup I was told has .08X intake and .10X on the exhaust.
http://www.sdpc2000.com/product/SD01...mshaftKit.aspx
Old 07-28-2009, 11:29 AM
6th gear's Avatar
ASA cam 226/236 525-525 110lsa.I also thought about running 1.8 rockers when i hook up the LTs.
